Sloped ceiling planes
alenal
Hello,
I am working on a project for my client and it has sloped ceiling planes, I cant get correct measurements for the slope.
Can someone please help me how to adjust my settings so I can get it correct. I have attached what  I keep getting, I tried adjusting base line height, ridge height and nothing is working. Thank you so much!
image.thumb.png.f01c0dee633ad56e73f435aa2e58b73a.pngimage.thumb.png.a7ace756ffacae3c247588d1be3175fa.png
22 hours ago, alenal said:
Hello,
I don't quite understand what issue you're having, I see that the second picture has roof a bit odd with a seemingly off centered ridge. Depending on the roof construction, it's generally best to draw the roof planes first and then uncheck flat ceiling in the room(s) below. Then add in manual ceiling planes at the pitch and heights that you need.
If you haven't already, make sure to go through the Chief training videos. They are generally excellent and should get you where you need to be.
Ceilings - https://www.chiefarchitect.com/videos/watch/69/ceiling-basics.html?playlist=96
Manual roofs - https://www.chiefarchitect.com/videos/watch/25/drawing-roofs-manually.html?playlist=95
Good luck
