Need Help Converting Draft Plan to Construction Documents
JC6100
Hello,
Would like to get some help converting a DIY level plan into feasible construction documents.  The screenshots are from a draft plan done in Home Designer; I can provide the files when necessary.  Currently planning on a slab foundation.  The heated square footage for this is ~3600sf. Construction location is north western South Carolina.
Let me know if more info is needed.  Would also appreciate any tips on the process.
Thanks
