Set up .plan for full size 1"=1"
tomm11
7 minutes ago, tomm11 said:
Sounds silly for an architectural program but I'm doing wood carving + want to draw a pattern
Do you have a question?  The default is already at 1:1  you scale it when you put it into layout, or if you draw it in something else manually.  By default you are already there.
1 hour ago, tomm11 said:
oh yea. when I import a 9 inch pdf + the the image scales to 34 ft all I have to do is divided by 45.33. The idea pdf changing the dimension scale was throwing me off. thanks
Select the pdf and use the resize tool on a known dimension.
 If there really is not much editing involved you might want to consider skipping the plan file all together and import directly to layout.
