Gawdzira Posted June 23 Share Posted June 23 I am just starting to work in X14. I am noticing an odd behavior. If I have placed an object from the Library into a plan file, when I switch to my layout file (by clicking into a new window) the last Library item I placed is now active again and wanting a new home in the layout file. After placing the library item other work has happened so the tool is not active in the plan view. Is this a know bug? 1 Link to comment Share on other sites More sharing options...
solver Posted June 23 Share Posted June 23 I don't see this behavior. Does it happen in a new plan/layout? With more than one library item? 1 1 Link to comment Share on other sites More sharing options...
Gawdzira Posted June 23 Author Share Posted June 23 This is on a plan started fresh in X14. It has happened with multiple library objects. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 23 Share Posted June 23 I've noted a similar situation. The selection of a Library Item acts like it's in "sticky mode" and you just need to terminate that tool. I don't know why it doesn't terminate automatically when switching from Plan to Layout - or Layout to Plan. Esc or Spacebar works for me to terminate the tool. 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted June 25 Share Posted June 25 To get rid of the “stickiness”, I’ve developed the habit of clicking on a folder in the library or the top of the folder window in order to cancel out of that item. It’s annoying since even pressing escape or the space bar doesn’t get rid of the item trying to place. 1 Link to comment Share on other sites More sharing options...
MoeGia Posted June 25 Share Posted June 25 I see it also. It also happens when moving between plan and elevation views when using custom library icon items. I don't care for the behavior. 1 Link to comment Share on other sites More sharing options...
robdyck Posted June 25 Share Posted June 25 It's worse than annoying. It's an absolute PITA. Please report it TS! 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted June 25 Share Posted June 25 Yes it's a PITA , happening Here too....... (BUG) Mick. Link to comment Share on other sites More sharing options...
