Wall Below Deck....turn Off
buzzsaw204
Try this - I believe it is the "official" way:
Specify the wall as a railing - doesn't matter what sort - or an invisible wall or railing should work as well.
Select the railing wall and open the dbx.
Structure panel>Platform Intersections>Invisible Walls and Railings>uncheck Generate Between Platforms.
Note from the help file states that this setting has no effect with a single layered wall.
  • Upvote 2
I kind of figured there is an "official" way of doing this. I just couldn't find Check box, and what its called, for it
thank you glw.
    32073
    smashing
    smashing
