Terrain Behind Retaining Wall
DRyeHD
I'm doing a residential addition that requires the terrain to be built up in front of the addition.  I've created a flat area (for parking) using the Elevation Region Tool.  I've placed a Terrain Wall behind it.  I've been adjusting things  and watching help videos for a couple of hours but can't figure out how to make the terrain behind the wall follow the existing terrain.
I've attached a screenshot of the plot plan and remodel plan with the problem areas indicated.  Does anyone have a solution on how to accurately modify the terrain behind the wall to get it follow the existing terrain line?
Normally I use a Foundation Wall for more Control and add my own Terrain Break along the top off the wall
with an Elevation Region either side of the wall, so in your case you might need to add say a 4" wide
Elev. Region along the bottom of the wall too, set to the correct height ( may need to play a bit )
Mick.
I'm getting close.  @Kbird1, I've used your recommendation for a terrain break along the top of the wall.  I tried using an elevation region at the bottom of the wall but got a little better control using an elevation line.  I've attached a screenshot of my progress.  I can't seem to get the grass off the back side of the retaining wall.  When I move it closer,  the terrain becomes sloped behind the wall as if it connects the the higher terrain.
Any suggestions on getting rid of the grass on the back of the wall?  If not, I will attach the remodel plan (would not show the existing terrain for comparison).
sometimes all it takes is moving the Terrain break 1/2" left or right
I normally use a narrow E.R. 2"- 4 " so most of it is hidden in the wall and for this probably interior is flat is off
And make sure none of the Elev. Data is crossing or touching each other , or they will fight for control of the TP
I make my Elev. line style Orange and give regions a 95" orange fill as well to make this easier to see , the orange will look darker anywhere it overlaps another ER for example. Terrain Breaks I make purple .....and dashed usually
It looks like you just need to move either the wall or move the Terrain Break to the middle of the wall.
What type of wall are you using?
I usually get everything correct with Elevation Regions, Elevation Lines and Terrain Breaks before placing a normal wall.
I usually don't use Terrain Walls or Retaining Walls.
36 minutes ago, HumbleChief said:
Hi Glenn, What do you mean by "normal wall"?
Thanks
Use a Foundation Wall, ( and edit in Elevation)  not Chief's Terrain Walls which have there own Terrain Break built in but you have less control
like when you want the top of the wall Level , not following the Terrain.
Mick.
Any wall apart from a Retaining Wall as they usually create too many problems, mainly with all the auto wall steps they create.
18 minutes ago, HumbleChief said:
Here's a plan that combines all the tips from the smart guys; Terrain Regions; Terrain lines; Terrain Breaks and Foundation walls
Couple more Tips......
Set you Terrain Break Transition Distance to 0 for immediate height differences Larry
and centered on the wall at least at 1st ..........
And make sure you pull the TR right to the Wall or a hair inside it , so it looks "cleaner"
at the transition and Chief can't take over control for that 1 foot or so to the walls , as if you don't take control CA will.
image.thumb.png.20bc2dca04bc4fcb3c1bce50a7873136.pngimage.thumb.png.07175f4e8a787c3cdd291337bdcd605d.png
image.thumb.png.bedba48240200e9406d38b815e87b436.png  image.thumb.png.c7e905f42fceed26b5d8d3a4e90ea307.png
and s with it centered on the wall..........
at the transition and Chief can't take over control for that 1 foot or so to the walls.
NICE - Hope it helps the OP.
@glennwso you put your walls in after you do the terrain mods? I'm using a terrain wall but based on discussion I'm going to change to a foundation wall. @Kbird1 thanks for the file.  @HumbleChiefthanks for the other tips. I had to knock out a few other things this afternoon but will report back next week when I'm back on that project. Have a good weekend all.
A Terrain Wall isn't a wall - it really is a terrain path - more like a solid, that will follow the terrain, cut and fill the terrain when running parallel to the slope and will follow the terrain slope when running perpendicular to the slope.
This is an L-shaped Terrain Wall:
  • Upvote 2
    32914
    smithro
    smithro
  • Similar Content
    • By TrimbachDesign
      Good afternoon Chief users,
      All of our projects to date have been pretty straightforward terrain-wise, and despite spending way more time on this than I can to admit, and watching all of the tutorials I am still scratching my head.
      A little background:
      The site for this home has a lot terrain character, swales, hills, etc. Due to this, we brought our survey crew out to GPS map the site. I followed the Chief tutorial to bring in the terrain data generated (very slick process). During the design of this home a goal was to minimize grading and to preserve the unique characteristics of the site. I decided to stick the uphill side of the home into the hillside with a taller retaining stem wall to "split" the grade over the width of the home.
      Struggles:
      To get the site grading to mimic what we envisioned, I used elevation areas, some with "interior is flat" checked, a lot of trial and error during this process. One terrain modification I did was creating a flat area around the front of the home for the entry, and parking. Coming off this elevation area is where I am struggling. I have tried using multiple elevation regions and elevations lines to force the terrain to build at a gentle slope off of this pad. From my calcs we could easily adjust the driveway grade to have an appropriate slope. The problem area (directly off the flat parking area) is about 12 feet of rise over 80 feet of run (15% slope). I just want this area to be filled to allow for an even 15% slope. I have bumped up line weights, colored them red, and removed unnecessary information from the screenshot attached below for clarity.
      Do any of you terrain wizards have any advice for me? I am happy to attach the plan file if desired.
      Thank you all,
      Austin
    • By Doug-ib
      This is my first time trying to bring in data collected from GPS into chief arch. I have converted the CSV file into a txt doc but when i bring it into chief arch the land/terrain looks very off; there are tons of spikes/triangles on the area and I'm unsure how to make it "smooth". Also unlike other programs I've used when I click a point I don't get a description of the point, meaning i cant tell if I'm looking at a shot of the sidewalk or a portion of the driveway, im wondering if there is a more effective way to input this data or a way that will allow me to keep my codes/point descriptions that I set when i was in the field.
      Any info/solutions on this topic would be appreciated.
      terrain.plan
    • By WhistlerBuilder
      Hi everyone,
      I am stuck on a tricky terrain issue. I am designing a multi family building site that has some relatively simple grading required for the parking lot and pedestrian access which chief cannot seem to accurately process. Perhaps I am missing a trick? I have uploaded the relevant portion of my plan so you can take a look.
      Basically I have a pedestrian access "sidewalk" coming on the property at a higher elevation, and a driveway leading to a parking lot at a lower elevation. The driveway and parking lot all have carefully calculated grades leading to the elevation I have set as top of parking slab (2159.00 ft). After days of messing with the retaining walls and terrain breaks I finally got the parking lot to work. Now the problem is that chief cannot seem to handle terrain topographic lines intersecting the top of a retaining wall / terrain break without creating absolutely batshit crazy peaks and valleys everywhere. Since the site requires that I have a sidewalk pedestrian access at the top of one of these retaining walls with a maximum slope of 2%, these crazy variations are screwing up my plan. I cannot seem to get rid of them except with flat terrain areas, which of course screw up the pedestrian access elevations. I can't just cheat and do stairs because this building needs to be handicap accessible. Chief cannot do terrain area's with a slope... something they should absolutely add!!!!!
      How do I fix this problem?
      I would really appreciate some help here as I have spent the last few days really struggling with the terrain features of chief and I am at my wits end trying to figure out this issue.
      Help_Plan.plan
    • By CBRF23
      Is there any way to raise a retaining wall so that it extends above the terrain, and add a top cap to the wall?
      I've got my retaining walls, they follow the grade pretty well, but I can't find the option to control height above grade on the retaining wall.
      I want to create something like the attached image.
      Thanks!
    • By payettedesigns
      Chief Friends:
      My business is swamped right now. I have 37 projects on the boards  21 additions and 16 new home projects as well as some kitchen and baths. We do not take on addition projects unless the client agrees to and pays for a complete re-draw of the as-built ( unless they have plans.) We do this because we are sold on the importance of 3D visualization for our clients. I have a very elaborate Lake House I am working on and would like help from someone who is and expert on incorporating terrain data from a dwg provided by the surveyor. We have complete contour elevations on this survey.
       I also would like to partner up with someone who needs work and has been using Chief Architect for at least 5 years. You can be a sub-contractor for us or we can hire you as full-time employee who would work remote. We have a benefit package, a bonus structure and a decent yearly salary that matches any entry level architect. You would also be required to make bi-monthly meetings at our Raleigh , NC office and your travel and lodging would be booked and paid in advance. I have field people who would do the as built measuring local and would either use room planner or draw direct from their lap top. You would take over at that point and create con-docs per local codes, collaborate with our structural engineer and create a basic 3D presentation.  We sub- the post production 3D work out to another company who takes the 3D to another level. I have five employees but 4 of them  are committed to commercial 3D projects which is the un- advertised part of our business. Myself and another employee cannot handle all of the residential projects we are inundated with. The ability to work in Revit and Sketch up is a plus.
      We would purchase a HP T520 plotter and update your graphic hardware and PC systems at our expense. We collaborate on Google Drive and have all the collaboration procedures an sop we created.
      You can email me direct at payettedesigns@nc.rr.com or Call me direct at 919-697-2428
