robdyck Posted May 15, 2022 Share Posted May 15, 2022 Chief will not properly clad a flush eave correctly unless.....(wait for it)...the exterior wall has at least 2 exterior layers!! This should be addressed because 1 exterior layer should be enough!! With 1 Exterior Layer: With 2 Exterior Layers: Link to comment Share on other sites More sharing options...
evergreen Posted May 15, 2022 Share Posted May 15, 2022 And while they're at it, update gable soffit and eave soffit mapping. Give option for them to be in either the same direction or like it is done in most cases rotated 90 degrees from one another. 1 Link to comment Share on other sites More sharing options...
AndrewSopher Posted July 26, 2022 Share Posted July 26, 2022 On 5/15/2022 at 11:39 AM, robdyck said: Chief will not properly clad a flush eave correctly unless.....(wait for it)...the exterior wall has at least 2 exterior layers!! This should be addressed because 1 exterior layer should be enough!! With 1 Exterior Layer: With 2 Exterior Layers: I just ran across the same problem. You solved it by adding a second layer to the exterior of your wall? Doesn't that create more problems elsewhere? Link to comment Share on other sites More sharing options...
robdyck Posted July 26, 2022 Author Share Posted July 26, 2022 Just now, AndrewSopher said: I just ran across the same problem. You solved it by adding a second layer to the exterior of your wall? Doesn't that create more problems elsewhere? It can but, generally no it wouldn't. I added a layer of housewrap with a thickness of 0". I just don't like adding '0' thickness layers unless I need them for a material list. It just makes the model more complex than necessary. I've informed Chief that this is a bit silly. Link to comment Share on other sites More sharing options...
HartDeNoble Posted July 26, 2022 Share Posted July 26, 2022 37 minutes ago, robdyck said: It can but, generally no it wouldn't. I added a layer of housewrap with a thickness of 0". I just don't like adding '0' thickness layers unless I need them for a material list. It just makes the model more complex than necessary. I've informed Chief that this is a bit silly. That is a weird bug, I will give that a try. Thanks! Link to comment Share on other sites More sharing options...
nicklas Posted March 17 Share Posted March 17 Is this bug solved now? Link to comment Share on other sites More sharing options...
gratebathroom Posted Monday at 08:00 AM Share Posted Monday at 08:00 AM On 7/27/2022 at 2:54 AM, robdyck said: It can but, generally no it wouldn't. I added a layer of housewrap with a thickness of 0". I just don't like adding '0' thickness layers unless I need them for a material list. It just makes the model more complex than necessary. I've informed Chief that this is a bit silly. That is a very strange bug, and I will experiment with that. dumb ways to die that's a good thing Link to comment Share on other sites More sharing options...
