Attic Conversion Exterior Walls projecting through roof Help
Robboulton
Can anyone help regarding the issue I'm facing when trying to draw an existing loft conversion. The exterior walls don't stop at the roof.
I have created a 3rd floor but kept the roof at the floor below. I tried the same but lowering the roof after adding the floor but the same thing happens.
Eventually it will have ashlar walls front and rear (knee walls I think you call them across the pond...).
Pic 1 shows before, Pic 2 shows after. You can see the issue.
Plan attached if it helps.
Thanks in advance.
Pic2.pdf Pic 1.pdf 20220420 - Taylor Existing.plan
