How do I extend counter so stool can fit underneath?
cbucks
7 hours ago, cbucks said:
want to remove cabinet but keep countertop and extend countertop to other cabinet counters
You can also select one cabinet and click on the Custom Countertop tool on your Toolbar ...assuming X12/13  and then grab the edit handle and pull it along the bank of cabinets.
image.thumb.png.4f9a1f1228d7dbd8ffb4e9776331b330.png image.thumb.png.6c51e89f38cf272e4f890bad50923436.png
Please add you SIG. so we know what Version you are using as it matters for a lot of answers.
If you are using a Home Designer Product you should be over on HomeTalk as those Products
can't do what Interiors and Chief Premier can......
https://hometalk.chiefarchitect.com/
you might also want to fully avail yourself of the CA KnowledgeBase ( KB) or FAQ as it's called Elsewhere
https://www.chiefarchitect.com/support/database.html
