Railings 2Nd Floor Railings Are On First Floor - Help
otisbradley
Go to solution Solved by otisbradley,
Hi - I've been in CAD for 20 years but new to CA
Finally figured out the cable rails but
My deck railings keep showing up on the floor below
also happens when I do an auto stairwell
or a manual stairwell created by railings
I am sure there is a little toggle somewhere
Thanks for any help !
if they are manually railings and you draw them too close to the edge of the deck/landing/staircase they will "fall" to the next floor ,also on staircases you may need to use the "follow stairs" setting in the DBX ( your little toggle? )
You have the railing designated as "Follow Stairs" on the Rail Style panel.
Tip: You will get faster dynamic rotations of the 3D model in Render mode if you turn off "Legacy Shadows" in the Render Preferences.
Yes if it's not a staircase make sure you uncheck it , it will jump backup once both rails are unchecked.........you haven't made a panel with that set as the default or something have you?
I don't see a falling issue with the interior stairs though they aren't connected to the upper landing ,perhaps you dragged it back playing since the plan doesn't look like the original image posted.
