Joining Walkthrough Paths
Electromen
I created a walkthrough path on the first floor and it extends up the stairs to the second floor.  On the second floor, I can see the camera, but can't extend the path.  All I get is a new camera 1 & 2. On the first floor it was fairly easy to connect and extend the walkthrough path.  I created the path using;  3D > Create Walkthrough Path.
Any suggestions?
Click add a frame and add click on the path line behind the leading camera, that camera will become camera #2 and the leading camera will automatically become camera #3.
I tried that and was able to make the line longer and move it into the mast. bedroom but it stays in a straight line.  I'd like to curve it into the master bath.
Use break line to make any curve you need
That worked to add curves thank you.  Usually when I draw the path, I drag so far and stop, then drag again from the last camera and it adds camera 1&2 but then joins the first path and it becomes one.  On the second floor, when I drag from the last camera, it stays camera 1&2 and does not join.  It starts a new path.
