Wall type for a "Wall Niche"?
ACADuser
Have you tried placing the niche while in a plan view?
Apparently, there is a problem in camera views if your wall is too thick.  Shouldn't matter how many layers you have or if any of them is marked as framing.  It's just the total thickness.
Thanks for the help.
Brian said this:
I was able to reproduce this issue and I have logged a report in our database.
The problem with placing the niche in 3D seems related to the thickness of the wall. For some reason it doesn't work once the wall becomes greater than 22" thick. You should be able to place in 2D though, but your case this is complicated by the windows on the top of the wall. You could work around this by changing the Vertical Stacking level of the windows in that wall. Doing this will allow you to place the niche in plan view.
