Dark Library Preview Panel
Designers_Edge
Has anyone else experienced the Library Preview panel being so dark, it is hard to see the example of a material.  I have changed it from a panel, to a cube, to a sphere and it is all the same.  If there is a control to change t his I have not been able to find it.  Appreciate any help.  Sharon Olsen
37 minutes ago, rgardner said:
Try changing up the rendering technique in the preview bar.
I was getting essentially the same thing with standard render.  I normally use vector view so had not noticed the issue but it would be great to figure it out for material viewing.
Seems to also be a PC and Nvidia issue if that helps to not narrow it down. ;)
