Extend Exterior Attic Wall to Cover Gable Below
A_Joseph_PE
Working on a very small house trying to duplicate a model that has been built locally a few times to learn the software better.
I can't seem to figure out how to extend this exterior attic wall over the lower gable
Can't load the plan since it is oversized??
It looks like the right side of the lower gable extends back into the house. Pull the back edge of that roof plane toward the front of the house, until the back edge is flush with the house exterior wall, and the attic wall should auto-build. I think.
Don't feel bad, I've been using the program for 25 years and even with Eric's (probably) excellent direction above I can't get it to build correctly either.
13 minutes ago, solver said:
I downloaded the plan to test my directions and ...
Fill in the gap with a ceiling plane.
One of the few places where use soffit material for ceiling might work if you have it set correctly as well.
