Room Selection on overdrive!
Francois
2 hours ago, Francois said:
Suddenly selecting one room highlights the whole floor plan including the foundation. Pressing Tab will select the chosen room. I never had that before. How do I get back to "normal"?
Are you initially seeing only the outside of the perimeter of the building hi-lighted, or are you seeing the whole floor plan hi-lighted?
29 minutes ago, Francois said:
Here is the zip
I don't think it zipped properly.  Give it another try and make sure the file is not open when you zip or upload.
I got an Early Termination Warning and the file is almost empty.
https://www.chiefarchitect.com/support/article/KB-00971/message-file-being-read-is-terminated-early.html?utm_source=Chief+Architect+Premier+23+x64&utm_medium=software&utm_campaign=Resource%3A+faq&utm_content=Error+ID%3A+272004602
Humm...   It seems to be functioning fine for me.  I assume you saved the file in the state that you were having the issue. Sometime I get a roof plane rather than a room but nothing that covers the entire structure.  Could you post a screen shot perhaps ?
When you get the entire floor, check the Object Layers.  I suspect you have a Polyline (maybe filled) that is being selected.  If that's the case you can either delete, lock or move to back.  I noticed that there is a polyline that encompasses several rooms - can be selected when all layers are on.
6 hours ago, Francois said:
Chopsaw, this is what I get when I select a room.
Ok that is what I suspected you were describing but like Joe I am unable to produce those results with your posted file even with the all on layerset.
Then plan you posted (or at least the plan I downloaded) is not the plan you're showing in the post (pic) above. You're pic shows a small room off the laundry room and family room. The plan I downloaded does not.
Also your original post states that everything is selected including the foundation but the plan you posted has no foundation.
