Attic Vents
capitaldesigns
4 minutes ago, capitaldesigns said:
When I place a gable end attic vent in elevation view the attic vent shows up in the floor plan. It shows correctly in elevation and section view as being in the attic.
How do I not have the attic vent show up on the floor plan ?
Thanks,
Mike
Make sure your correct floor is activated in your elevation view when you place the vent.  You probably drew it on a different floor.
