Note Schedule-Notes populate in different scales in schedule
gravattedesign
This has me completely perplexed. I have created several Note Schedules for my project and when I go to Layout, they are scaling at different scales (THIRD PIC) AND as in the FIRST pic below, Notes show up in the CAD DETAIL Schedule at different scales. The Bath Elevation is set at 1/2" Scale and the Note Layer text style is set at a 1/2" Text Style..
Regarding the Layout Sheet (3rd Pic).. The bath notes are referenced on 1/2" Scale plans and Interior Elevations, The Plan notes are referenced onto 14" Scaled plans.
Questions to Start:
1. How are schedules supposed to be assigned to a text style scale in the CAD DETAIL Space versus, The Note layer Text Style in the Plan or Elevation and Finally the imported Scale of the Schedule into Layout??
2. What happens if the same Notes are used across different scaled plans and Views? Such as a 1/4" Plan and a 1/2" Interior Wall elevation view?
Thank you kind folks for any light you can shed on this issue.
