Odd notches in my parapet walls?
ACADuser
if I move the wall to be shorter ands then back again, it loses the floating piece, but also leaves it extended over
the wall viewer shows
if i delete the perpendicular attic wall it goes back to what you had and the floating piece
i think the cap is trying to cover the attic wall.
if I move the main wall away from the attic wall. it shows correct(ish). had to adjust the roof plane as well
but probably not what you want
From tech support:
The reason for the jog in parapet walls on those two sides above the entry is because the entry room is marked to have a flat ceiling over it and so that adds structure to the height of that room, whereas the adjoining rooms don’t have that ceiling structure. A quick solution would be to open the room specification, go to the structure panel, and uncheck the box for flat ceiling over this room. Then use the ceiling plane tool in the roof tools to manually draw in a ceiling plane.
