Tornado Room
RobUSMC
16 hours ago, Joe_Carrick said:
Probably - but Robert could copy it into an X-12 plan and then create it as an X12 Symbol.
Is there a way that actually works Joe ?  Copy and Paste does not seem to work with symbols to go back to previous versions.
Do you have the original X13 drawing before the conversion to Symbol?  If not, then export to SKP and import that into X12
I am not sure that would work.  I can't even past an X13 cad line back into X12.
Perhaps .3DS but definitely not .SKP from Chief unless you are already working in the next version.
I have SSA but I usually wait a few more months before upgrading to a new version to give more time from them to work out the bugs.  Its just been so busy I have not had the time it takes to do the whole time consuming merge.
