BUILD FRAMING/Platform extends into adjacent room-New Framing Group?
Member Statistics
Similar Content
By basilbabaa
SITUATION: X13 3D renders, when compared to X12, appear blurred, washed out, less vibrant in quality and the vector renders have excessive line weights in X13
Rather than hijack a previous topic thread, I am starting this topic as a result of a side conversation that emerged here-in:
It appears that there are others experiencing this same issue, and so I thought I would begin this here in it's own topic thread.
Here is a Dropbox link to image and video files (generated on both a i9 and M1 Pro Max chips) depicting the issue: https://www.dropbox.com/sh/9zt4tagbuhsfkbi/AABsTnIW6DjT5uExeP6e5mcAa?dl=0
As a note, I have already opened a support case with Chief Technical Support and they have graciously offered to look into it:
If anyone else is noticing lesser quality output with 3D rendering in X13 as compared to X12, perhaps we can share our experience and thoughts here as well as with support towards a workable solution.
By tinadelllic
Hi all!
I'd like to share some of my library content that I feel may be useful for others. These pieces are a mixed bag - some original work, but many are chief pieces that I modified or conveniently grouped. I plan to add more from my collection over time. Please feel free to use/edit/adapt as you see fit!
Tina
SHARE #1: ELECTRICAL
GFCI-DRAWER.calibz GARAGE-OPENER+GFCI:WP.calibz FURNACE-ELECTRIC+220V.calibz 6-INCH-EXISTING-CAN-LIGHT.calibz 220V (W:H).calibz AC+DISCONNECT+GFCI:WP_220V.calibz CLEARANCE-ELEC-PANEL-NOTE.calibz DUPLEX-DRAWER.calibz EV-CHARGER+50AMP.calibz GARAGE-OPENER+GFCI:WP.calibz RCPELEC LEGEND2022.calibz UNDER-TOP-CABINET-LIGHTING.calibz W:H-ELECTRIC-AND-220.calibz
By Renerabbitt
Do you have 10+ years in the software and wonder if you've been missing some tips and tricks? Have you been able to break the 15 hour condoc set?
Maybe you are a proficient user that wants to know everything that there is to know in Chief.
Rendering, Automation, Resources, Symbols, Quick Tools, Style Pallets, PDF Tools, Templates, and more.
We believe in lifting the community up. All of our tools and resources are available to you. With training that can be personal, team oriented, prerecorded, livestreamed, interactive. We offer training in over 15 softwares from Drafting and Detailing to Modeling, Advanced Texturing, Procedural Workflows, Node Based Design, Macro Creations, DAMs, Automation, VR Workflows, Streaming Overlays and Masks and much much more. Tell us your needs and we will connect you with the package or the right resource.
Some example learning modules:
Concentric Jump your dimension strings
Enter-input your jumps and Enter-close your DBX's
Snap jump your door widths, concentric jump your windows
Alt behavior tips, contain-selection and deselection workflows with tool restrictions.
Tons of cabinet tools and tips, including custom one-off parametrically modelled vanities and more.
Custom Toolbar Icons and Custom Library Objects.
Toolbar Switching Tricks and Library workflows
Other Offer Services Posts:
By Renerabbitt
Renderings, and rendering training. Click on the links in signature for more info.
This rendering was rendered using Chief Architect Premier X-13 with no post-production.
More renderings in my user gallery or click on the links in the signature. How can I help you?
By Bee-am
Hi everyone,
I'm experiencing an interesting phenomenon with Cabinet Shelf Specifications that contain 3 or more library-based shelves in Chief Architect Premier X13. As indicated below, when I add a 3rd unique library object (i.e. wire shelf) to a shelf, somehow the previous library-based shelf (2) "breaks" and changes from (1) to be the 3rd library object. As such, I wanted to find out if that's the intended behavior or it's a bug - and whether there are any useful workarounds. I could have used separators directly at module-level but the cabinet module needs to be covered by double doors.
