Roof Thickness Default
stevenyhof
22 minutes ago, stevenyhof said:
When I set the roof structure thickness to 7.25, the roofs are still generated at 3.5
https://www.loom.com/share/58d662203eb545dfb7acf75239cde336
Thoughts?
Thank you,
Steve
You have "trusses" checked in the Build Roof DBX. That will override the Structure value and instead use the setting in the Framing Default, Trusses which I suspect is set to 3-1/2".
Ah!! Thank you very much!
