Floor and Ceiling Framing not generating in X12
gravattedesign
 I have difficulty troubleshooting WHY my ceilings and floor framing isn't generating when Auto Build Framing is run. I have checked all the room default settings as well as the framing default settings and all seem to be set correctly for my project (2x10 floors, 2x6 ceiling). The plan file I am working with was purchased from a Designer who worked on the house several years ago and assembled the As-Built model. That said, This is a recent situation with the framing. a week ago Auto Build Framing worked fine.  What may I be overlooking?
One other note: this issue appears to only happen where the Second floor exists. Main floor rooms with just attic space above, DO generate ceiling and floor framing.
Edited by gravattedesign
added comment
