Subtraction in solids
stevenyhof
In this video at 14:30 the presenter shows how he makes a copy of the solid, adjusts it and then subtracts the one from the other. All looks straight forward.
However, some time ago when I did this, I had a popup come up when I did not read, I only checked the box and closed it. Doing so changed things and now I am always left with the solid that I want to remove. I end up having to delete the main (makes a copy some how) and delete the solid I want to subtract.
Here is my result...
https://www.loom.com/share/09256a327b46425d901075f05289dd5b
My question is, where do I turn that popup back on, in some way get back to having it work as shown in this video?
Thank you,
Steve
12 minutes ago, Joe_Carrick said:
Have you checked "Preferences" and/or "Defaults" ?
Does this happen with all Plans or just with a particular Plan ?
I looked into Preferences and Defaults and cannot find anything related. Not sure what to really look for either.
It happens on all plans in X13 - new plan and old
I just went back to X12 and tested and that gives me the popup
