Display & Print non-solid lines in layout. X6
jscussel
Go to solution Solved by jscussel,
When sending an elevation to layout, I can't get the foundation to display non-solid line styles.
I have a dash line selected for the layers Footings & Foundation prior to sending to layout.
I am able to go to layout and using the "Edit Layout Line" tool and change the lines to dash.
Am I doing something wrong or is this feature broken in the latest update?
Jon
Michael,
That changed the wall outline in elevation view to dash. But in layout the lines are still solid..
I thought that the layers "Footings" & "Foundation" were where you changed the line style.
It works fine for me.  Did you make sure to open the elevation view from the layout and update it??
OK here is what worked.
Change the layer "Walls, Foundation" to a dash style. Uncheck "Use Edge Line Defaults".
Jon
Now that is surprising. I thought Joey had the correct answer when he said do not do that. I must look at this in the AM, maybe I am missing something.
