Update an existing layout with revised template
cjanderson66
Go to solution Solved by rgardner,
  • Solution
24 minutes ago, cjanderson66 said:
my address has changed and I want to update the existing layout sheets with a new template. How do I go about doing so?  Anybody got any ideas of how to make this change.
Are you totally redoing your layout template or just your title block?
If you just want to change your title block open up the new temlate and the old layouts and go to page 0 copy from new title block delete existing and paste hold position into the old layout.
Ryan,  Thank you for you expert advise.  I knew it was something as simple as that and I just missed it.
Chris
