solver Posted October 25, 2021 Share Posted October 25, 2021 Just another method. Make Pony Wall. Lower wall is all drywall and width to cover bottom of stairs. Drag wall bottom up in elevation. Link to comment Share on other sites More sharing options...
AvoyeDesign Posted October 28, 2021 Share Posted October 28, 2021 I use this method, but can you clarify why this needs to be a pony wall? I just use a standard wall set to no room definition. Also, I usually drag up in cross section through the stairs to get a snap on to the stair structure, as well as to use "make parallel" to find the stair angle. Link to comment Share on other sites More sharing options...
