1" Scale Detail Template gone in X13?
PMMully
Go to solution Solved by Chopsaw,
  • Solution
1 hour ago, PMMully said:
I was playing around and noticed this template is not under CAD details in X13, checked in X12 and it is there. Did I delete it by accident or did things change.
It is in the X12 and X13 Residential Template files and likely others that I did not check.  You may have deleted it from your own template but you could reload it if you like.
There should be virgin templates stored here by default :  C:\Program Files\Chief Architect\Chief Architect Premier X13\Templates
