Railing columns not being Consistant.
DeLayDesign
My client has a very specific look in mind, "H" shaped columns.  I've managed to create them as a 3D item and import them as a column; however, when placed they all seem to act as I want them to, except one.  What's the solution to this without having to place them all manually?
TIA.
Adam
The location at the start or end of the railing wall is what determines the position. You will need to play with turning them off and/on per the wall section to see which one is the position you want.
In other words, the longer wall at the edge of the deck looks to have one correct and one not. I would turn the start and end off for that wall and see what it gives you by allowing the shorter side walls determine the corner post.
