The program is already running. OK, I want to run it anyway
puntloos
Go to solution Solved by Chopsaw,
1 hour ago, puntloos said:
I guess I'll have to be somewhat careful trying to edit the exact same file so better make a copy etc.
Yes you need to be very careful that if you have the same file open in two instances that one file is only used as a reference or you will end up with quite a mess.
I'm not sure I understand why you need to open the second instance at all.  There should be no reason you can't continue to work with the open instance where the Ray Trace is running.
Ray tracing of a walkthrough. X13 is fully 'frozen' with a "frame x out of xxx" window slowly progressing.
