3D Views Not Showing Up
BAGrant
Go to solution Solved by BAGrant,
Has to be something with your system. I would reboot and try again. If that does not fix it I would think it is your video card. If you post your computer specs with your profile information someone may know whether your video card is sufficient.
You could also post the plan for others to test but I don't think it is the plan.
I use the video card (NVIDIA)control panel. "Manage 3D Settings" under "3D settings" and then "Program Settings". There is a drop down list to customize and if Chief isn't on it you just click the add button, select Chief and click "Add selected program" at the bottom. I don't change any of the Global settings at this point but I'm sure some of the experienced users do some adjusting.
I'm not on my office computer right now so can't do a screen shot but if you any problem I can take one later.
