changing templates
seanf123
Not exactly but there are a variety of tools that can make it easier to change the style of objects within a plan.
You can import defaults from a template plan (or any other plan) into an existing plan.  This will change your defaults but won't necessarily change the objects that are already modeled unless they are using dynamic defaults.
You can also setup and use style palettes to quickly change the style of objects in a plan.
You can also use replace from library to quickly change objects within a plan.
You can also use the object painter to quickly transfer settings from one object to one or more other objects.
You can always just group select objects to quickly change their style settings all at one time.
4 hours ago, seanf123 said:
such as a design done in kitchen and bath template, would like to change to using a modern day american template.
Sounds like possibly you are using Home Designer Pro and not Chief Architect Premiere?
