Room Divider
Ed_Orum
Chief changes the wall so that it can provide a usually appropriate vertical structure at the height change.  When you don’t want a vertical wall at the height change and would prefer to see a single line, I recommend using a Custom Wall Type.  Just copy the OOB Room Divider wall type and set the thickness to .01”.  Name it something like MY Room Divider.  Because the wall already technically has a thickness, Chief won’t change it, and because the wall is nothing more than a single layer Air Gap, it won’t provide anything at the vertical transition areas.
  • Like 2
