Convert DWG to PLAN
DanceOfFaith
Go to solution Solved by Alaskan_Son,
DWG files are natively 2D only. One imports the 2D file and then traces over its lines with 3D tools for walls, windows, doors etc.. It is not "click of a button" fast, the fully 3D model or .plan file takes time to recreate. One would have to see the complexity of the existing design in order to offer you a bid or estimate.
Not sure that was the intent of the request.  I don't think Suite has an option to import DWG.
4 hours ago, DanceOfFaith said:
Would anyone be wiling to convert a DWG file to PLAN format for me? I am only using the Suite version.
Why not post the file and consider it done.
Current versions of Home Designer Software can import .dwg files (not true in the past)
I assumed they wanted a fully 3D version of the 2D AutoCAD file for use in Home Designer Software.
  • Downvote 1
