Walls being generated from floor below
mfraley
Hello,
I have designed a house that 2 of the 4 walls with an overhang from the ground level by a few feet (see attached).  When adding the shed roof, 2 walls are self generating walls past the 2nd level. If I remove the roof it goes away. I am at a loss.
I have never had this happen before when designing the next level. Thank you in advance for suggestions.
Working in 12
