We still can't control HEADER LINES? I can't believe it!
dshall
Scott,  I thought it was the "Top Edge Lines"  that we could not control ?
It seems that the "Opening Header Lines" are on a layer and can be controlled.   That must be what you are using but would like the "Top Edge Lines" to have the same level of control ?
Thanks Chop,  you are kind of correct.  2 problem with that:
1-   It cannot be controlled on a door by door basis
2.   the opening header lines is for the header,  I want it to highlight the arch opening including the drywall,  not the arch opening framing
so...  we still need control of the TOP EDGE LINES......  thank you very much
1844280268_ScreenShot2021-05-05at11_09_45AM.thumb.png.7aee20097bc55f117a6d287cca25d8fb.png
