WINDOW OVER DOOR IN SHOP FRONT WITHOUT MULLION
Hi all
I have looked at posts re shop fronts but not sure how I achieve something like the pics below?
Am looking to do a butt joint glass on a feature wall with a door frame only to give the look in the first pic.  I've tried doing it as a rail but not sure how to get rid of the upper door frame/mullion and get the look of the second pic?
Does anyone have any work arounds?
Thank you
This works in vector, will need something extra to work in Standard or PBR.
Bit fussy to do. Using 0.01" thick room dividers set in a U 1/8" apart, place, then break wall, reverse wall directions so they alternate, drag to connect to room divider.
glass wall.plan
    29506
    Berretta969mm
    Berretta969mm
