Window label default?
ACADuser
So I changed the Window Default to "Specify Label" and added this:
%automatic_description%
Top @ %height%
But the new windows in plan view default to "Automatic label" is this normal behavior?
I would also like %height% to be Feet - Inches, do I need a user macro to do that?
Hopefully this will be a whole lot easier in X13 but changing the default for windows only seems to apply to newly placed windows, so you would need to open all your existing windows and use a Number Formatter for the height value.  ie. Top @ %fi(height)%
Here is Eric's explanation:
