Setup Default Views from .plan to .layout
I have found a way to set up and automate my default template .layout file using my default template .plan file.
In the video below I step through how to set up your .layout so that all your common views are already in place on your default template .layout file.
I use pre set Plan Views (with print ready layer sets) of each floor. (Set up in the default template)
I use pre set Cross Sections (My four elevation views). (Set
