Foundation-Slab on Grade with brick ledge
31Construction
I’m new to chief architect and like what I see so far. I having issues with creating the foundation for a slab on grade with a brick ledge. I currently use AutoCAD but may switch to CA if possible. Can anyone share how they would create this foundation. I attached a foundation plan and some typical details. Thanks for your time.
Thanks Joey,
I can't figure out how to make the ledge.  For this instance, I would like a 1.5" x 1.5" ledge.
I have the X9 trial version but will be purchasing if I can figure out this foundation.  Below is a snipit of the settings I have so far but as you can see the ledge is not there.
