Rotate Plan
builtright3
Sounds like you must have used Rotate Plan View.  That tool essentially just rotates the entire drawing board.  You probably wanted to rotate the building and as such, should set the Plan View rotation back to zero and then use Edit Area to rotate the building and any other desired drawing elements.
Thank You! As usual, you saved me again!
