Creating a pie-cut corner wall cabinet
kwhitt
I'm trying to create a pie-cut corner wall cabinet.  I've tried two methods and neither give me the appearance I'm after.
The first image shows two individual wall cabinets meeting at the wall corner.  As you can see the top rail overlaps back to each wall.
The second image shows Chief's out-of-the-box corner wall cabinet.  I don't want the additional frame stiles in the corner.
I was hoping someone had a workaround for this other than building the cabinet using P-solids.
@MarkMc
  • 1 month later...
@MarkMc Hi, found this post and I'm struggling with the same thing. I downloaded the model you attached,  and gone through it to match my cabinets to what you did.... I am trying to figure out what you did to remove the stiles in the corner of where the cabinets meet. Can you explain? Thank you so much!
