has anyone had trouble with purchased catalogs that won't import?
Sroberts67
You should first check to make sure that the catalog is compatible with your product and version.  If you look for the little "I" symbol and hover over it, then you will see what versions it will work with.
More info about importing downloaded libraries can be found here:
https://www.chiefarchitect.com/support/article/KB-00090/obtaining-library-content.html
If all else fails, then you might want to contact tech support.
