Exterior walls not showing
since1937
53 minutes ago, solver said:
My comment above about the roof was to get you thinking about why the roof would be where it was.
Roofs build over walls whose height is controlled by the ceiling of the room they form.
Of course this is with automatic roofs but looking at the picture I would venture a guess this was drawn manually???
29 minutes ago, since1937 said:
Soon as I added the roof, all but 2 or 3 walls disappeared, taking the roof to the terrain. I checked the ceiling height again to see if its at 0", and its set at 120". I've attached the file. would you mind taking a look?
Backyard Design.plan
As mentioned above your roof planes are set @ varying heights and below ground.  Please do yourself a favor and try auto roofs.  It is a really easy plan for auto roofs.
image.thumb.png.09c93bcfe66dffd102f8aca5c48a1076.pngimage.thumb.png.a012553c39bdbd1f209bac8b9b4e78cb.png
