Help gap in flooring
DianeP
4 minutes ago, Alaskan_Son said:
This roof plane is your problem...
Check out the shape in the upper right quadrant.
Awesome.  You found it.  I am still not sure why it wouldn't work, but I took out the extra segment around the stairs (there were 2. I made it one using the fillet tool)  Thanks bunches!
You bet.  Roofs can get problematic when you have extra unnecessary segments, particularly when those segments are at off angles that don't proper;y correspond with a wall or another roof plane.
Well done Michael! I figured it must be a roof, but I didn't find that one. Good work.
