How do you keep the inside lights on?
J_Ward
Is there a way to keep the inside AND outside lights on in this view? I can manage to do one or the other depending on where I start my camera view.
This was drawn in X10, but I do have X12. If it matters.
Thanks
You can turn lights on and off and adjust other properties in the 'Adjust Lights' panel. It is accessible from the drop menu on the 'Adjust Lights' button in the menu bar (look for the light bulb symbol). You should also click on 'Light Set' in the DBX for your camera. Here's a good overview from the Knowledge Base https://www.chiefarchitect.com/support/article/KB-00777/working-with-light-sources.html
