Sign in to follow this
John_Charles
WHY IS THE COLOR BLURRED ON THE LAYOUT ONLY?
Hi all
I've got a small issue in that I'm sending elevations both in live view or plot view with color and getting a color shift in the layout only.
If I open the elevation itself from the layout all is at is should be, yet the layout itself looks like the below.
Any thoughts as to what I'm doing wrong?
Thanks
That seems a bit extreme.  Is that the live or plot view or are you saying they present the same ?  Did you update your plot lines ?
Someone may need to take a look at your plan file as I thought that issue had been fixed.  Do you have an unusually wide terrain plot ?
They are both the same...and yes I have update plot lines.
It is a wide terrain plot as it's a sprawling house.....
Is this by chance after you have printed to pdf?
No, the image above is a screenshot from within a page of the layout....
I think that is likely it if you are more than a couple of hundred feet.
You may want to send the file to tech support as it appears to still need some work.
Not sure if you might be able to turn off the terrain layer and update your plot lines and then turn the terrain back on. Unfortunately that does not work with live views.
Ok thanks I will give it a try.... (the terrain is around 500 ft wide in these elevations...)
That should maybe address the plot line offset.  As for the blurry colours they will be fine when you print or you can temporarily clean them up in your layout by zooming in on the view and then updating but it will make you system work hard to maintain that resolution.
    29070
    sonofson
    sonofson
