Wynsong 2 Posted November 28, 2020 Does anyone know where this wall artifact comes from and how to get rid of it? It is related to the wall and ballooning through the ceiling. If I do a flat topped wall and then add an attic wall there is no artifact. Doesn't matter if you choose through wall on either or both walls. Looks like a bug to me and I'll write it up that way if no one has an explanation for it. Thank you. Share this post Link to post Share on other sites
Chopsaw 637 Posted November 28, 2020 Possibly an artifact of the attic wall. Check attic level of plan view. If not post the plan file. Share this post Link to post Share on other sites
DRAWZILLA 780 Posted November 28, 2020 You could try to re-build the wall or turn on automatic wall framing. Share this post Link to post Share on other sites
Kbird1 814 Posted November 29, 2020 You tried adjusting the wall in 3D or Elevation , which may or may not be the Issue since you may have done that after seeing the artifact? Last pic shows "Default Wall Top is NOT Checked.... so Chief has NO control of it..... you do.... try rechecking it 1st..... M. Share this post Link to post Share on other sites
