View clipping when zoomed in
CAcygrymus
I have noticed of late that when zooming in near objects in Perspective Full Overview, I can only get so close before it clips the object. For instance a wall may suddenly be clipped through to show it's layers when the camera gets too close. Say you put an object like a mirror or such on a wall. If you zoom in on it in perspective view to see detail of the mirror, you can only get so close before the clipping occurs.
See below, a simple brick on a wall. I can only zoom so close to objects before the camera completely clipps them out of the view.brickonwallclose.thumb.jpg.c28ad530e2156a00cd1a69299f818593.jpg
23 minutes ago, steve_stuart said:
check your clip distance in your camera defaults
Ah, thanks, that solved it. Is that a new setting in X12? I cannot recall it clipping like this in the past.
The default for a few of the camera types is 24". Just curious, but in what scenario would that be desired?
