Surface Mount Electric Symbols
MarkMc
Thanks for sharing. I had to update some symbol options to make them work after importing:
2Gang surface Switch - Did not originally rotate to the face of the wall i was placing it in. In the Symbol Specification menu under options the check wall mounted, switch, and 110 volts boxes
Single Switch Surface Mt - Big offset from wall surface. Set the Y Position Origin Offset to 45" and the object shows correctly but not sure how to get the symbol to follow.
Surface Duplex - No Issues
Surface Duplex 17.5 - No Issues
Surface Quad - No Issues
