Adding plates to beam by default
CRHDesign
42 minutes ago, NRST8TRKR said:
Add a plate to a beam then add that to your user library. Next time it is ready for use.
 Hope this helps.
      Have a great week, Ken
Thanks Ken. Pulling the beam out of the library and then resizing it is more work than just dropping the beam manually and adding the plate though.
You are correct Ken..all the workarounds are more work than simply making sure your beam height is correct by default to account for the plate. I simply wait until time to work on framing plans and copy a sill plate...since all the relevant heights and widths are correct...and just paste them as needed and size.
Yeah, it's frustrating to do sections because of all the little things that need to be fixed and have no way of setting up as a default. Currently, the easiest way to do it is to delete the beams out of the sections and just replace with my own saved CAD block, which seems counterproductive to the program functions.
